10-08-2007 10:15 PM
I am facing a problem with device discovery.It shows the loopback IP address of the devices instead i want to see the management IPs.Can anyone give a solution for this asap.
10-09-2007 04:32 AM
Do you have "Use LoopBack Address" checked under CM -> Admin -> Device Discovery -> Discovery Settings -> Preferred Management IP? If so, uncheck that and look again after the next discovery cycle.
10-09-2007 05:27 AM
it is exactly what yjdabear wrote
and for devices being already discoverd you could change the Management IP in Campus Manager - Topology Services. Open a Network View, highlight a device and use the advanced menu (right mouse click) and go to 'Change Management IP...'
10-12-2007 04:19 PM
Thanks buddy
This was the case.I unchecked it & it worked
