LMS telnet problem
rmoneal
Community Member
We're running LMS 3.1.  Whenever I try to telnet to any device I get a message "Application Not Found".  What application is it trying to open and how do I change it?
Joe Clarke
I assume you mean from Device Center?  If so, then you need a telnet.exe on the server.  You may need to follow http://forums.vandyke.com/archive/index.php/t-2074.html (or something similar) to make sure the telnet:// URL is handled properly.
