LMS/VMS ???
wrwiii122
What is the difference between Ciscoworks VMS and LMS. They look the same to me execpt that one does a little more and costs alot more.
nhabib
Level 9
Level 9
Parts of LMS are included in VMS
If you are looking for security management, then you need VMS
If you are looking for network management, then you need LMS
Parts of LMS? Could you use VMS as a network managment software? The reason I ask is that I found VMS sitting on the shelf but currently use solarwinds for network managmetn but would much rather use cisco.
It all depends on what you are trying to accomplish.
VMS' capabilities are listed at:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_3/index.htm
