01-14-2016 05:41 AM
We need to add four voice servers (cucm) to the LMS
Is there any known procedure to do this ?
The goal of adding those voice servers to LMS , is to "search through telephone extensions"
01-14-2016 07:25 AM
hi,
it is just like any other device ..router or switch..
adding CM , will help you tracking the IP phones etc.. and you can generate reports on them...
Thanks-
Afroz
***Ratings Encourages Contributors ***
01-14-2016 08:13 AM
Thanks for the reply 🙂
Can you just help me on how to track phone extentions and generate reports with LMS ? Where to navigate to reach that ?
01-14-2016 08:49 AM
you can generate different types of reports in LMS,
check the below link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/user/guide/reports/lms42_reports_guide/inv_reports.html
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/user/guide/reports/lms42_reports_guide/switch_port_report.html
Thanks-
01-17-2016 03:57 AM
01-17-2016 09:30 AM
select ,voice communication..
