LMS2.5 problem
vinay_8812
when i trying to config. LMS2.5 on window server, the server info shows this report
network.pl
*** Default servers are not available
*** UnKnown can't find 127.0.0.1: No response from server
what it means ? it's shows FAIL
no devices is populated in DCR
FAIL nslookup failed
miheg
Level 9
Level 9
No errors warnings during install??
Is the hostname in the DNS or at least resolvable.
Keep in mind that this hostname can only be changed using a procedure.
Michel
David Stanford
Are you also seeing errors for database.pl?
