LMS2.6 DFM Notification Groups & ACS-Integration
rkoll
I cannot create Notification Groups. In the group add dialog there are no devices listed in the "all" tab. Searching is possible, but after "select all" nothing is selected.
I'm using dfm2.0.8 and lms26 is integrated with ACS-Server. After looking the failed log in ACS-Server i see a authorization failed with user "system" (?) with the comment "service=dfm cmd=view_aad authorize-deviceGroup*... ".
Other parts of LMS are working properly even with ACS-integration.
Have anybody similar problems or can anybody help ?
6 Replies 6
solaris 9 - you mentioned a patch in the given conversation ...
I wrote a patch that fixes this, but you need to open a TAC service request and reference bug CSCsh74986 to get it.
jclarke,
im hitting the same error here and getting the same log message from the CSCsh74986, how can i get that patch?
thanks in advance..
As I said before, one needs to open a TAC service request to get the patch.
