LMS2.6
nawas
Level 4
Level 4
Is LMS2.6 an upgrade bundle or something can be downloaded? I currently have CS3.0.4/LMS2.5.1
Thanks.
David Stanford
Hey Nawaz,
you can download the LMS 2.6 bundle on CCO at:
http://www.cisco.com/cgi-bin/tablebuild.pl/lms26
Its pretty easy to install too
Dave
Thanks Dave
Readme file says in the prereq that that I need LMS 2.5.1 and I just found out that I have LMS2.5, CS 3.0.4 and RME 4.0.3. Can I stil install LMS2.6 or do I need to upgrade to LMS2.5.1 first? I'm little confused here.
Hey Nawaz,
CS 3.0.3 (you have 3.0.4) and RME 4.0.3 are part of LMS 2.5.1
Looks like you already have it installed and should be able to go to 2.6
Dave
You're already at LMS 2.5.1. CS 3.0.4 and RME 4.0.3 correspond to LMS 2.5.1 versions.
