11-09-2011 08:58 AM
Did setup the Logrotation Schedule, applied and got a response that it scheduled. If I call this again, everithing is shown as default. And I cant find Logrotation Job in the global Job-Browser.
are there any hints how to can find this Logrotation Job?
Steffen
Solved! Go to Solution.
11-09-2011 01:47 PM
I do not know of a way to see the configured schedule through the GUI. But you can open a DOS box and issue the command "at" and you see the scheduled entry.
The job is scheduled by the task scheduler of the operating system not LMS "internaly" . Thus said, on solaris you have to call crontab of casuer with this command:
crontab -l casuer
11-09-2011 01:47 PM
crontab -l casuer
11-10-2011 01:11 AM
Yes you are right, you can find it beside the DB-backup-Job in:
crontab -l casuer (Solaris)
I hope this forum thread is read by someone of the product management as well:
Its very confusing to have a unified LMS job management, where you should rely on to can find 100,00% everything of 100,00% of any jobs in LMS and have 2 execptions left.
Thx Martin, you are the best:)
