Load Balancing Router Suggestions
rij079
Hi guys
I'm having 3 different ISPs and right now they are all connected to routers and then to the network, we have only one server and around 50-60 users. In the current scenario two ISPs are only used if the main ISP is down and also it has to be done manually i want to introduce a load balancing router into the mix so that all 3 ISPs are being used at the same time and in case of failure the switch over has to be automatic. Please help me with any suggestions.Thanks in advance
Mark Elsen
 - For 50 to 60 users I don't think that load balancing is an urgent priority ; but automatic fail-over is. I would more look into firewall-solutions (not an extra router) which can do PBF (Policy Based Forwarding). These can do automatic fail-over (and probably load-balancing too).
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
