02-13-2019 12:45 PM
I was setting up a new 3850 and entered the following line
username security privilege 15 password XXXXXXX
omitting the 0 between password and the actual password.
I am now unable to access the switch. Upon boot I am asked for username which I supply and then immediately get kicked out. Other relevant commands
aaa new-model
aaa session-id common
aaa authentication login default local enable
aaa authorization exec default local
line con 0
exec-timeout 15 0
transport output all
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 15 0
privilege level 15
logging synchronous
transport input ssh
line vty 5 15
exec-timeout 15 0
privilege level 15
logging synchronous
transport input ssh
I cannot rename the packages.conf file from ROMMON as it is read only. I cannot format the flash either. I attempted booting from TFTP server via emergency-install but am still presented with a username prompt.
I have tried this as well
Any suggestions on how to wipe either the password or the device back to factory. It is not in production and I have the setup script so starting from scratch is not an issue.
Solved! Go to Solution.
02-18-2019 08:33 AM
02-13-2019 12:58 PM
02-13-2019 04:13 PM
I have tried this via ROMMON and continue to get access denied or read-only depending on the file or file system I am working with. You can only access emergency-recovery from ROMMON mode
Thank you though
02-13-2019 01:35 PM
Hi @idratherbesurfin,
Having entered this command should not have blocked access:
Omitting 0 only indicates that the key that follows will be in plain text:
SWITCH1(config)#username security privilege 15 password ?
0 Specifies an UNENCRYPTED password will follow
7 Specifies a HIDDEN password will follow
LINE The UNENCRYPTED (cleartext) user password
You should be able to access with the user security and the password that you entered.
If this is not the case, there should be another reason for the blockade (if I'm not wrong).
02-14-2019 03:15 AM
I must have typed the username incorrectly. I have been searching for a way to reset the username from ROMMON but everything leads to a password recovery.
02-14-2019 07:45 AM
I must have typed the username incorrectly. I am setting up another 3850 with the same script and have not had any issues. So how do I go about clearing out the username or resetting the switch to factory defaults?
Thank you!
02-14-2019 07:06 AM
I attempted to SSH to the machine and the credentials were still rejected. Unless the username is wrong I am stumped. I cannot see the config to verify this. Additional configuration info
line con 0
exec-timeout 15 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 15 0
privilege level 15
logging synchronous
transport input ssh
line vty 5 15
exec-timeout 15 0
privilege level 15
logging synchronous
transport input ssh
aaa new-model
02-18-2019 08:33 AM
