Log Not Generate
vengatthiya
Community Member
Cisco Switch 4503e Not Generate the logs
IOS - cat4500e-universalk9.SPA.03.04.05.SG.151-2.SG5.bin
Power Supply Up Down But Switch Was Not Generated The Logs
Mark Elsen
             - Do you have a syslog server configured correctly in the running configuration ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Would you post the first several pages of output from the command show log? Also would be helpful if you post the output of the command show run | include log.
Rick
