LOGON PROBLEM
ahmedmt786
Community Member
I'm using CiscoWorks 2.5 on windows 2003, and I dosen't have any service pack installed. When I'm try to logon, to server, after entering user ID and passowrd I'm getting below error. I have verified the sequences of services, and re-started the server as well.
Error
"You don't have permission to access /cwhp/LiaisonServlet on this server."
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
frankzehrer
Level 8
Level 8
Hi Mohammed,
please try the following:
Drive\Program Files\CSCOpx\setup\support\resetcasuser.exe
Where drive is the driveletter where CW is installed.
Hope that helps,
Best regards,
Frank
Hi Frank,
I had tried the above, It's ask for the password, I had re-set the password as well, but still the error is same.
Thanks and best regards.
Mohammed Tajammul Ahmed.
Hi Frank,
Thanks a lot for your help, I had tried the same again, now its working fine.
One's again thanks a lot........
