Looking for OID string for Rx/Tx Power on Nexus 5548
khansen
Hi all,
I'm trying to use SNMP to graph the Rx and Tx power current measurements that you get when you issue the "show interface ethernet x/yy transceiver details" command on a Nexus 5548, but I'm not having much luck tracking that down the correct OID string.  Has anyone had any luck doing that?  Thanks!
Kim
Hii
Could you try 1.3.6.1.4.1.9.9.91.1.1.1.1.4.xxx OID to get the RX and TX sensor value for the transreceiver and 1.3.6.1.2.1.47.1.1.1.1.2 to get index value of interface through description.
It's working fine in Nexus N9K-C93180YC-FX.
Dipti Ranjan Dash
