10-05-2006 07:00 PM
Hi all,
Is management of VG248s done only by Unified Operations Manager or does anyone know if CS LMS will provide support?
Cheers
Solved! Go to Solution.
10-05-2006 11:57 PM
LMS does support these devices in the sense that they are visible in Campus Manager, and DFM can poll for events. The VG248s are also manageable by CUOM. In all cases, they must be running 1.1(2.1.5) or 1.2(1) or later.
10-08-2006 06:25 PM
Neither suite does config management for these devices.
10-05-2006 11:57 PM
10-08-2006 04:17 PM
Thanks for that. Does CUOM manage configs for the VG248s?
10-08-2006 06:25 PM
10-08-2006 06:29 PM
Thanks Joe, saves on a lot of reading.
11-01-2006 12:47 PM
since config backups are not supported...does anyone know how to remove them from the 'failed' list on the config archive management summary within RME?
11-01-2006 12:55 PM
You cannot other than not adding them to config sync jobs. However, system config sync jobs will fetch all managed devices, and this cannot be changed.
