Management VLAN 2960
Roger Richards
Good day,
I just got some 2960's. I initially set them up with the same vlan as my data network using the web interface but now I want to change them from vlan 10 to vlan99  for management . I don't see a way to change the management vlan in the web gui. see attached file. help if you can.
packetrends
Roger,
If you have CLI access you should be able to create vlan 99 and assign the ip address you desire to use for managing the device:
Switch(config)# int vlan 99
Switch(config-vlan)#ip add a.b.c.d a.b.c.d
Switch(config)#ip default-gateway a.b.c.d
Below is a link that might be helpful:
https://supportforums.cisco.com/discussion/11138161/how-configure-management-vlan
packetrends
Roger,
