MEMORY_ALARM : Memory threshold crossed
aridy
I have a Cisco ASR 9010 Router with a total memory of 4G. I often get the following alarm:
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-4-MEMORY_ALARM : Memory threshold crossed: Minor with 409.586MB free
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USERS_INFO : Top 5 consumers of system memory (419416 Kbytes free):
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USER_INFO : 0: Process Name: bgp[1054], pid: 598306, Heap usage: 937348 kbytes, Virtual Shared memory usage: 54872 kbytes.
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USER_INFO : 1: Process Name: ipv4_rib[1145], pid: 598314, Heap usage: 348052 kbytes, Virtual Shared memory usage: 28840 kbytes.
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USER_INFO : 2: Process Name: nvgen_server[349], pid: 262267, Heap usage: 72752 kbytes, Virtual Shared memory usage: 7244 kbytes.
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USER_INFO : 3: Process Name: ipv6_rib[1146], pid: 598294, Heap usage: 62484 kbytes, Virtual Shared memory usage: 27176 kbytes.
RP/0/RSP1/CPU0:Jul 7 15:19:11.306 : wdsysmon[457]: %HA-HA_WD-6-TOP_MEMORY_USER_INFO : 4: Process Name: cfgmgr-rp[164], pid: 233560, Heap usage: 25948 kbytes, Virtual Shared memory usage: 11384 kbytes.
After it stays active it is cleaned by itself with the following notification:
RP/0/RSP1/CPU0:Jul 7 15:26:58.208 : wdsysmon[457]: %HA-HA_WD-4-MEMORY_ALARM : Memory threshold crossed: Normal with 412.000MB free
Is there any way to free memory space without affecting the service?
Aridy
Mark Elsen
 - Not sure about your question, you may also want to check the current software version the device is on, sometimes later releases can resolve such issues.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
Thanks for your reply. My IOS is Cisco IOS XR Software, Version 5.1.3[Default].
Is it considered an old version and if so, what new version do i need?
Aridy
- Then it would certainly be advisable to upgrade :
         https://software.cisco.com/download/home/282414851/type/280805694/release/7.0.2
 (take the suggested release, but study release notes and upgrade guidelines too)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
