07-08-2020 03:28 AM
I have a Cisco 866VAE-K9 and wanna reset it to its factory settings. It was configured but I don't know the password. So I tried to press the reset button and the router recognized it. But after that it boots in the old config and doesn't reset. It also shows the old hostname.
Tried it 3 to 4 times but it don't want to work. So power it up press the reset button and wait for 10 - 15 seconds. Am I doing something wrong? I don't know how to reset it without knowing the old password when the reset button isn't working for me.
Configuration Reset Button Pushing Event Detected! System Bootstrap, Version 15.1(4r)M3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 2013 by cisco Systems, Inc. C860VAE advanced k9 platform with 256 MB of main memory Booting flash:c860vae-advsecurityk9-mz.155-3.M2.bin boot: Launch entrypt: 0x80800000 Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## [OK] Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco IOS Software, C860 Software (C860VAE-ADVSECURITYK9-M), Version 15.5(3)M2, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Sun 07-Feb-16 03:34 by prod_rel_team CK:bcm6300_get_dsl_type.... CK:PM_HW_C866VAEK9... flashfs[6]: 444 files, 18 directories flashfs[6]: 0 orphaned files, 0 orphaned directories flashfs[6]: Total bytes: 55351296 flashfs[6]: Bytes used: 48082944 flashfs[6]: Bytes available: 7268352 flashfs[6]: flashfs fsck took 2 seconds. flashfs[6]: Initialization complete. This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 866VAE-K9 (revision 0.3) with 234496K/26624K bytes of memory. Processor board ID GMK184400UZ 1 DSL controller 1 Ethernet interface 4 FastEthernet interfaces 2 Gigabit Ethernet interfaces 1 ATM interface 1 Virtual Private Network (VPN) Module 255K bytes of non-volatile configuration memory. 57344K bytes system flash allocated [OK][OK][OK] Router IOS Configuration Recovery is in progress... Warning: The current export protocol does not use templates. CK: setDefaultAdslMode :vdsl_ipc_sku_multi_j_isdn.. CK: BcmXdslCoreGetAfeBoardId....gModemSkuType=5 CK:AdslCoreLoadImage ... inside vdsl_ipc_sku_multi_j_isdn.. CK: BcmXdslCoreGetAfeBoardId....gModemSkuType=5 Press RETURN to get started!
Thanks for help
07-08-2020 01:09 PM
