12-06-2006 02:58 AM
what is the advantage of loading MIBs into NMS ? If I want to read the value of particular OID is it ok to use the that particular OID or I have to load the MIB.
How the NMS reads the interface type from MIB for a particular value of ifType?
12-06-2006 04:10 AM
The advantage of loading MIBs into NMS is that the OIDs will be translated from numbers to words.
For example, the NMS would map 1.3.6.1.2.1.2.2.1.3 to ifType
12-06-2006 09:19 PM
Thank You.
when MIB is loaded into the NMS how it is organized? In a tree structure ?
How the NMS finds a particular OID from that structure?
12-06-2006 09:39 PM
The MIB structure is a logical tree, and most MIB parsers use a tree data structure to represent it in memory. The internal tree choice and implementation of a specific NMS dictate exactly how an OID is resolved to an object name (e.g. breadth-first search, depth-first search, etc.).
Regardless, each branch of the tree has a numerical identifier, and MIBs map those identifiers to a textual name. For example, 1.3.6.1.2.1.2.2.1.3:
iso (1)
org (3)
dod (6)
internet (1)
mgmt (2)
mib-2 (1)
interfaces (2)
ifTable (2)
ifEntry (1)
ifType (3)
You can use tools such as http://jaguar.ir.miami.edu/~marcus/snmptrans.html to help visualize this tree.
