09-02-2020 01:15 PM
Hello, I need find the SNMP MIB for monitor my users connected by VPN SSL on my Cisco ASA 5525.
I don´t know if this it is possible or no.
Any tip about where I can find this MIB please post here.
thanks
Solved! Go to Solution.
09-02-2020 01:35 PM
OID's added to CISCO-REMOTE-ACCESS-MONITOR mib to provide sesssion statistics info. :
crasEmailNumSessions (Oid: 1.3.6.1.4.1.9.9.392.1.3.23 )
crasEmailCumulateSessions (Oid: 1.3.6.1.4.1.9.9.392.1.3.24 )
crasEmailPeakConcurrentSessions(Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1.3. 25 )
crasIPSecNumSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 26 )
crasIPSecCumulateSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 27 )
crasIPSecPeakConcurrentSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1.3. 28)
crasL2LNumSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 29 )
crasL2LCumulateSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 30 )
crasL2LPeakConcurrentSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1.3. 31 )
crasLBNumSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 32 )
crasLBCumulateSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 33 )
crasLBPeakConcurrentSessions(Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3.34 )
crasSVCNumSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 35 )
crasSVCCumulateSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 36 )
crasSVCPeakConcurrentSessions(Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3.37)
crasWebvpnNumSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 38 )
crasWebvpnCumulateSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3.39 )
crasWebvpnPeakConcurrentSessions (Oid: 1.3. 6. 1. 4. 1. 9. 9. 392. 1. 3. 40 )
following MIB:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-REMOTE-ACCESS-MONITOR-MIB
09-02-2020 01:35 PM
following MIB:
09-03-2020 08:47 PM - edited 09-06-2020 02:19 PM
Hello, thank you but I did´t understand how to identify the username in the return of follow command
snmpwalk -v2c -c my_community 172.16.1.254 1.3.6.1.4.1.9.9.392.1.3.21.1.2
SNMPv2-SMI::enterprises.9.9.392.1.3.21.1.2.8.48.57.56.57.52.50.50.57.85549059 = STRING: "tunnel_ssl_XX1"
SNMPv2-SMI::enterprises.9.9.392.1.3.21.1.2.13.106.101.108.97.115.116.105.99.46.111.108.101.103.101294081 = STRING: "tunnel_ssl_XX1"
For Exemplo, at the first output line what is the sequence number which represents the username ? because the second output line is very different. I should like undestand how to interpretation these sequence number regard where is the username.
I found the follow link about this issue but it no explain how to get the sequence number regard username
thanks
03-24-2024 07:45 AM
Check out VPNTTG (VPN Tunnel Traffic Grapher) is a software for SNMP monitoring and measuring the traffic load for IPsec (Site-to-Site, Remote Access) and SSL (With Client, Clientless) VPN tunnels on a Cisco ASA. It allows the user to see traffic load on a VPN tunnel over time in graphical form.
Advantage of VPNTTG over other SNMP based monitoring software's is following: Other (commonly used) software's are working with static OID numbers, i.e. whenever tunnel disconnects and reconnects, it gets assigned a new OID number. This means that the historical data, gathered on the connection, is lost each time. However, VPNTTG works with VPN peer's IP address and it stores for each VPN tunnel historical monitoring data into the Database.
For more information about VPNTTG please visit www.vpnttg.com
