Migrate from Mikrotik router to Cisco Router
ShahabAhmad4412
Hi! i am running isp. I want to change my router and the network infrastructure.
I have 400 users on my isp. I want some information about the physical hardware,
what hardware is complete my requirement. can cisco have the same function of bandwidth management as mikrotik?
2 Accepted Solutions
balaji.bandi
Let me give some advise here. since you Migrating from Mikrotik to Cisco Environment.
First ask some simple questions :
1. do we have budget to go for cisco ( i know Mikrotik hard rock bottom price based on the Linux based Router - had many clients who like that product very much - for small investment)
2. what kind of bandwidth you have and looking to have with a cisco router.
3. Cisco ISR 4K can do the job.
cisco Router on the box yes and know depends on config and hands-on experience you have on cisco routers.
what kind of bandwidth management are you looking for on a user basis?
For me sounds like you running a small Home user-based network here (buying bandwidth from ISP ? is this correct ?)
BB
yes, you can use the Cisco router as PPPoE Server with Radius authentication for your Packages to offer clients, this required some integration.
DMA radius server  -  can use the same for your requirement.
BB
balaji.bandi
BB
Thanks. yah I have a budget. i have different packages for my client and I use CIR bandwidth and share my network .i can create different speed packages for the client, as they need. can you tell me how I can create a PPPoE server and client option same as MikroTik? how I can manage the client's speed in the cisco router in MikroTik. I can use the DMA radius server for that purpose.
BB
Thanks.
