MinFail on 6509 Mod
Kurt Warner
I have a 48 port POE ethernet moduel that is shoing me minfail. I tried to reseat it that didnt work any ideas how i can fix this , or is this just hardware  going bad? Here is the show mod , diagnostic module
C6509-Rtr1#show module
Mod Ports Card Type                              Model              Serial No.
  3   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-45AF  SAL1109HZUT
Mod MAC addresses                       Hw    Fw           Sw           Status
  3  001b.0ce4.a460 to 001b.0ce4.a48f   2.2   8.4(1)       8.5(0.46)RFW MinFail
Mod  Sub-Module                  Model              Serial       Hw     Status
  3  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1109J0QU  2.3    MinFail
Mod  Online Diag Status
  3  Pass
C6509-Rtr1#show  diagnostic module
Current bootup diagnostic level: minimal
Module 3: 48-port 10/100/1000 RJ45 EtherModule  SerialNo : SAL1109HZUT
  Overall Diagnostic Result for Module 3 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
    1) TestScratchRegister -------------> .
    2) TestNonDisruptiveLoopback:
   Port  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
   Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
    3) TestLoopback:
    4) TestNetflowInlineRewrite:
         U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U  U
    5) TestAsicMemory ------------------> U
    6) TestEobcStressPing --------------> U
    7) TestFirmwareDiagStatus ----------> .
    8) TestVDB -------------------------> .
Nick Chen
Hi Kurt,
how's the case?Thanks!
diduarte
IEEE Voice Daughter Card WS-F6K-48-AF MinFail
So far re-seat the line card and if this does not work the part needs to be replaced. On the other hand module WS-X6148A-GE-45AF  is affected by VCCP component issue Field Notice: FN - 63743. Cisco has been working with some customers on an issue related to memory components manufactured by a single supplier between 2005 and 2010. These memory components are widely used across the industry and are included in a number of Cisco products. Below is the link where you can check additional information.
https://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63743.html
