Modify startup-config using text editor and tftp
marcobinda
Hi all,
my question is : how to change the configuration
file using a text program (how to save it ?),
and then copying this file with a tftp server.
I tried using a word text editor (word pad, notepad)
but as I save it, it become a text file and the
router doesnn't recognize it as config file,
so the copy tftp startup doesn't succeed.
Thanks in advance.
Marco.
paddyxdoyle
Level 6
Level 6
Hi Marco,
When you do a "Save As" from within notepad, put the filename in speech marks (e.g. "running-config") and change the "Save as type" to "All Files"
Paddy
Thanks Paddy,
I did it using the gedit/linux editor and
it worked at the first try.
The problem still remain using MS editors.
Notepad isn't able to format the file in a readable
way (it shows the char, but doesn't go to the new line), while Word and Wordpad format the file
in the right way but as i want to save it, they
don't let me save as type "all files" transforming it to a text file.
Anyway, thanks to you and linux I solved the problem.
Best regards,
Marco.
