monitor switch and port banwidth usage
cedric.spence
I have a catalyst 4506 switch with CATOS version 8.4(4)GLX.
Does software exist that I can use to monitor the bandwidth of the switch and each port?
I basically want to zero in on the machines that are producing high volumes of traffic.
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
You can monitor the traffic pattern on each port by enabling the SPAN sessions.
You need to have some Packet Capture Tool (Ethereal) to verify the traffic.
>> Refer attachment for SPAN Configuration
Nevertless,
>> You can enable "ip accounting" on Switch port but make sure it may cause increase of CPU load sometimes.
In addition,
>> You can monitor the Traffic Load of the Swtich (may be Switch port ==> i am not sure) in a Graphical manner (5 mins avg, 30 mins avg, 1 day avg, etc.,) with MRTG Tool.
Refer: http://oss.oetiker.ch/mrtg/
PLS RATE if HELPS
Best Regards,
Guru Prasad R
