Showing results forĀ
Search instead forĀ
Did you mean:Ā
monitoring FTD 2110 IPSec using SNMP MIB
Qays
I have Cisco Firepower 2110 and I want to monitor VPNs I tried (CISCO-IPSEC-FLOW-MONITOR-MIB) it didn't work for me
I tested it as shown
snmpwalk -v3 -l authPriv -u USER -a SHA -A "PASSWORD" -x AES -X "PASSWORD" 10.10.10.10 CISCO-IPSEC-FLOW-MONITOR-MIB::cikeTunLocalValue
CISCO-IPSEC-FLOW-MONITOR-MIB::cikeTunLocalValue = No Such Instance currently exists at this OID
so I tried to retrieve tunnels using ( CISCO-REMOTE-ACCESS-MONITOR-MIB)
note: the fields contained example values
 snmpwalk -v3 -l authPriv -u USER -a SHA -A "PASSWORD" -x AES -X "PASSWORD" 10.10.10.10 CISCO-REMOTE-ACCESS-MONITOR-MIB::crasGroup
CISCO-REMOTE-ACCESS-MONITOR-MIB::crasGroup."1.1.1.1".735416321 = STRING: 1.1.1.1
CISCO-REMOTE-ACCESS-MONITOR-MIB::crasGroup."2.2.2.2".744243201 = STRING: 2.2.2.2
CISCO-REMOTE-ACCESS-MONITOR-MIB::crasGroup."3.3.3.3".735330305 = STRING: 3.3.3.3
but the problem here is that the ( CISCO-REMOTE-ACCESS-MONITOR-MIB) didn't get all active IPSec tunnles
I need advice on how to monitor IPSec VPNs using SNMP
vpnttg001
Check out VPNTTG (VPN Tunnel Traffic Grapher) is a software for SNMP monitoring and measuring the traffic load for IPsec (Site-to-Site, Remote Access) and SSL (With Client, Clientless) VPN tunnels on a Cisco ASA. It allows the user to see traffic load on a VPN tunnel over time in graphical form.
Advantage of VPNTTG over other SNMP based monitoring software's is following: Other (commonly used) software's are working with static OID numbers, i.e. whenever tunnel disconnects and reconnects, it gets assigned a new OID number. This means that the historical data, gathered on the connection, is lost each time. However, VPNTTG works with VPN peer's IP address and it stores for each VPN tunnel historical monitoring data into the Database.
For more information about VPNTTG please visit www.vpnttg.com
