Monitoring inside an MPLS cloud
kradjesh13
Is there a monitoring system to monitor the type of traffic and ports for some of the sites inside a MPLS cloud.
Rajesh
Jan Nejman
Level 3
Level 3
I think that the easiest way is to use a netflow. You can also use a static probe, etc, but the netflow is almost supported on Cisco devices.
Jan Nejman
Caligare, Co.
http://www.caligare.com/
