Monitoring interface traffic
CSCO11629535
Community Member
I'm using a solution to monitor the traffic passing through the interface
SWCORE connecting with my router.
The Linux machine (sniff) has two interfaces (eth0 and eth1)
Etho (manages the machine) connected to the interface to another interface g1/18
(Sniff) connected in g1/27.
Add the following command:
monitor session 2 source interface Gi1/48
monitor session 2 destination interface Gi1/27
But I don't capture nothing.
I show monitor out following:
Session 2
Type : Local Session
Source Ports :
Both : Gi1/48
Destination Ports : Gi1/27
Encapsulation : Native
Ingress : Disabled
Learning : Disabled
Do what doing wrong? Help me??
Michel Hegeraat
Level 11
Level 11
try this  "monitor session 2 source interface Gi1/48 ?"
Doesn't if show an option to span ingoing, outgoing or both traffic directions?
I think you need both
Do you see traffic on the spanport Gi1/27 if you do a  "show interface Gi1/27"  ?
The counters should go up
The interface Eth0 should be in promiscuous mode to capture the traffic other then for its own mac address or broad/multicast
Cheers,
Michel
