N9K unable to detect syslog pattern on EEM
dfernandes786
I'm trying to execute an EEM script on a leaf switch when the following syslog message is generated.
LEAF01 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/50 is down (Link failure)
Following is what I have configured
event manager applet linkdown
event syslog pattern "%ETHPORT-5-IF_DOWN_LINK_FAILURE:.*"
action 2 cli python bootflash:script.py
To cause the syslog message, I shut a port on the spine switch connected to the leaf.
The syslog message above is what appears in the leaf.
I'm not sure why EEM is not detecting the syslog message to trigger the script to execute.
balaji.bandi
As per i see you are calling python script inside EEM process. this is not good. instead of what you processing you can directly process with EEM script to take action and test.
As per my understand there are some limitaion which may not be good to call inception scripts inside one process.
BB
