NAM does not boot (Module Failed SCP dnld)
KLAUS FRIEDEL
hi,
we have got  a big problem with our NAM (WS-SVC-NAM-1) - it does not boot.
We have got a second one and in an other chassis. I changed the chassis, and RAM and Flash from the other one. RAM and Flash are ok.
We checked the disc (hardware) with an Ontrack-tool  -it is OK.
environment: 6500 VSS
sh logging:
Jun 17 13:18:24: SW1_SP: Switch 1 Physical Slot 7 - Module Type LINE_CARD inserted
sm(cygnus_oir_bay slot7), running yes, state wait_til_online
Last transition recorded: (offline)-> empty (remove)-> empty_clr_persist (remove)-> empty (insert)-> may_be_occupied (timer)-> occupied (known)-> can_power_on (yes_power)-> powered_on (real_power_on)-> check_power_on (timer)-> check_power_on (power_on_ok)-> wait_til_online
Jun 17 13:25:49: %C6KPWR-SW1_SP-4-DISABLED: power to module in slot 7 set off (Module Failed SCP dnld)
Whats wrong with NAM and what to do?
Can anyone help us?
thanks Klaus
Nael Mohammad
Level 5
Level 5
Post the "show mod" output. Is this the only module having issues?
What NAM version are you using?
Have you tried to reset the module? "hw-module module X reset?
Hi Nael,
we removed the disc for hardware check. Today in the morning I put it back in the NAM and inserted the module in the chassis -  what a surprise - it works . For me is it unbelievable but it is true. After a module reset it still works.
regards Klaus
