03-28-2006 06:25 PM
My outlook clients use random high ports to connect to Exchange servers. when a host uses port 2234, the NAM tags these pakets as soulseek. This is a false positive and I woud like to know how to modify the nam so that it wont identify port 2234 as soulseek.
Is this possible?
03-29-2006 07:45 AM
Mine does exactly the same. I think you can go in and define your own protocols to stop this.
Look under setup -> protocol directory.
You can edit soulseek in setup -> protocol directory - application group.
Darren
03-29-2006 09:20 AM
Thanks Darren,
The caviat to this is that an application can only belong to 1 application group. so I have to remove Soulseek from the peer-to-peer group and add it to email group.
So now I supose that if I have a real Soulseek server on the network it will flag these packets as normal e-mail traffic?
Not sure of the impact of this action.
