NAM module booting from maintenance image
luis.elvira
Hi everybody,
I have a NAM in a 6509-E chassis with sup720, and every time I reset this module it boots with its maintenance image instead of with its application image. The only way I have meneged to boot the NAM with application image is with the command "hw-module module <slot> reset hdd:1". But, if I reset it without "hdd:1" argument (by default) or I reload it, the NAM boots again with maintnance image.
What can I do to set application image as the default image?
Thanks in advanced and best regards,
Luis
Joe Clarke
Try hardcoding the hdd:1 into the config of the 6500:
boot device module hdd:1
Then see if the default reset command works.
Joe Clarke
