05-16-2006 05:25 AM
I have four 6509's in my core switch cluster: two act as Core switches, two act as Distribution switches. The Distribution switches connect directly to our 200+ production servers (via 48-port gig blades). I have two NAM2's, one in each Core. I've started to mess around with SPANs etc but still have a lot to learn.
My question is: I would like to get RMON stats on the servers connected to the Distribution switches. Can I do this with the NAM's in the Core, or do I need to move them to the Distribution switches to get full visibility? Also, will such a move require downtime on ANY of the switches?
Thanks!
- Neil
05-22-2006 07:05 AM
Are you specifying to access the RMON mode on the switch?
05-22-2006 07:34 AM
I don't see any reason why you would move them out of the Core switches. They should collect stats fine from there providing you have properly set up the span/rspans
05-22-2006 10:03 AM
You can look at the deploymnt guide: http://www.cisco.com/en/US/products/hw/modules/ps2706/products_implementation_design_guide09186a00801a75ac.html
