NAM2 QUESTION
ozlemduran
hi,
I ve just installed a NAM2 card on a 6513 and I setup the IP address,gateway...But I cant ping any system from NAM. How should I configure the NAM interfece vlan, which interfaces belong to NAM?
THANKS
rmushtaq
Level 8
Level 8
Is the Cat6K running IOS or CatOS?. For CatOS, you do not need to configure a VLAN as the NAM management port because that port automatically synchronizes to the VLAN assigned to interface sc0 on the supervisor engine. Note: You cannot set the NAM management port VLAN with the set vlan mod/port command.
For IOS, To configure a VLAN for the NAM management port, you must use the analysis module mod_num management-port access-vlan vlan_id command on the switch
