NAT not working
Diegoncho
Good afternoon everyone, yesterday I tried to do a lab to test NAT but it doesn't work for me, any recommendation?
The pc takes ip from vlan 20
///ROUTER//
Router>enable
Router#confi
Router#configure t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#DO SHOW RUN
Building configuration...
Current configuration : 3344 bytes
! Last configuration change at 01:12:48 UTC Sun Oct 2 2022
version 15.9
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp pool delegacion
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip cef
no ipv6 cef
redundancy
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ipv6 ioam timestamp
access-list 1 permit 192.168.20.0 0.0.0.255
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
login
transport input none
no scheduler allocate
end
Router(config)#
Router#
/////SWITCH////
SWITCH(config)#DO SHOW RUN
Current configuration : 2729 bytes
! Last configuration change at 01:05:47 UTC Sun Oct 2 2022
version 15.2
service compress-config
hostname SWITCH
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
switchport mode trunk
negotiation auto
switchport access vlan 20
switchport mode access
negotiation auto
negotiation auto
negotiation auto
ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec ^C
IOSv - Cisco Systems Confidential -
Supplemental End User License Restrictions
This IOSv software is provided AS-IS without warranty of any kind. Under no circumstances may this software be used separate from the Cisco Modeling Labs Software that this software was provided with, or deployed or used as part of a production environment.
By using the software, you agree to abide by the terms and conditions of the Cisco End User License Agreement at http://www.cisco.com/go/eula. Unauthorized use or distribution of this software is expressly prohibited.
^C
banner incoming ^C
^C
banner login ^C
^C
line con 0
line aux 0
line vty 0 4
end
////PC///
10 Replies 10
rajen.jakhar
Configuration looks fine , Make sure interface Gi0/0 , obtaining IP address from DHCP from Internet Cloud .
sh ip it brief
sh ip nat trans
interface g0/0 if it has ip
only
ip route 0.0.0.0 0.0.0.0 interface g0/0
is need to forward traffic via g0/0 (NAT outside)
the command does not work
this only notify not error
now try ping from PC and check
It doesn't work
rajen.jakhar
dont see vlan 20 is created on switch , are you able to ping gateway of pc ?
Can you Ping 192.168.20.1
Also you can try to ping from  router interrace ,
ping 8.8.8.8 source 192.168.20.1
and check sh ip nat trans
ping from pc to gateway vlan 20
ping from the router
nat
Could it be platform problem? i am using cisco modeling labs with this cloud as internet
can you ping 8.8.8.8 from router ??
I think the connection between router and Internet is failed
