Iv got a task to upgrade a NCS 1.0.2.29 to a Prime 2.2. When going through the different release notes from NCS 1.0.2.29 and all the way up to Prime 2.2.
I found the following path:
NCS 1.0.2.29 to Prime 1.2.1.12
Prime 1.2.1.12 to Prime 1.4.0.45
Prime 1.4.0.45 to Prime 2.2
But in this doc http://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-4/quickstart/guide/cpi_qsg_1_4.html#25242
it says Upgrading Cisco Prime Network Control System 1.1.2.12 or 1.1.3.2 to Cisco Prime Infrastructure 1.4 is not supported directly. If you plan to upgrade from Cisco Prime Network Control System 1.1.2.12 or 1.1.3.2 to Cisco Prime Infrastructure 1.4, contac...
And i cant find the PI-upgrade-bundle-1.2.1.12.tar.gz fil on cisco.com
So im a bit confused on how to go on whit this
Thansk
Jakob
