NCS 1.0.2.29 to Prime 2.2 path
jakob_storm
Iv got a task to upgrade a NCS 1.0.2.29 to a Prime 2.2. When going through the different release notes from NCS 1.0.2.29 and all the way up to Prime 2.2.
I found the following path:
NCS 1.0.2.29 to Prime 1.2.1.12
Prime 1.2.1.12  to Prime 1.4.0.45
Prime 1.4.0.45 to Prime 2.2
But in this doc http://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-4/quickstart/guide/cpi_qsg_1_4.html#25242
it says Upgrading Cisco Prime Network Control System 1.1.2.12 or 1.1.3.2 to Cisco Prime Infrastructure 1.4 is not supported directly. If you plan to upgrade from Cisco Prime Network Control System 1.1.2.12 or 1.1.3.2 to Cisco Prime Infrastructure 1.4, contac...
And i cant find the PI-upgrade-bundle-1.2.1.12.tar.gz fil on cisco.com
So im a bit confused on how to go on whit this
Thansk
Jakob
Marvin Rhoads
I'd recommend you contact the TAC. I believe the note is obliquely referring to a necessary patch that needs to be applied when moving from NCS to PI 1.4.
The TAC can provide access to any necessary patches as well as intermediate upgrade packages that may no longer be offered on the download site.
