Need Device package for Call Manager to install in LMS 3.2
comsameer
Can anybody help me regarding device package for Cisco MCS 7835-I3 [Cisco 7800 Series Media Convergence Servers] . I have added Call manager in LMS 3.2.1 but showing ? as there is no device package installed in LMS.
with regards,
Nik
Vinod Arya
Windows Servers and Domain Controllers are classified as Media Servers if (1) CDP is enabled on them, OR (2) the HOST-RESOURCES-MIB attribute hrSWInstalledName is populated with the string Unity. (The latter indicates that it is a Unity Server, which DFM displays as a Media Server in the Host class.
Mostly the CCM/UC's are day one ready for support. Please check if your CCM is snmp reachable without which it will not be coming to a known state and appear as a ?.
Please run a invenotry and see if is successful and if fails share the failing error. Enable SNMP service on CCM and configure the SNMPv1/v2c RO community string.
This community string should be added to DCR.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Ok, but how about config fetching? It drops errors like :
CM0056 Config fetch failed for OSTA-10001-CM1 Cause: CM0204 Could not create  DeviceContext for 163 Cause: CM0206 Could not get the config transport  implementation for xxx.xxx.xxx.xxx Cause: CM0202 Could not access 172.25.110.1 via  SNMP. Action: Check the Read Community string Action: Check if required device  packages are available in RME. Action: Check if protocol is supported by device  and required device package is installed. "
or if itsn't supported how to disable config fetching for CM devices to avoid generating tons of error messages?
