need help ASAP - cannot open topology service LMS 4.1
bebygone24
hello all,
i am new in cisco LMS . now i am in client site  installing cisco LMS 4.1 in UCS server-rack version. we did it well for  the installation, and the LMS working properly until i cannot open  topology service.
i attached the error message
any advice ?
I am using it on windows 7. I cut the GUI down in an atempt to make my pc faster
enable logging and show console for java in the control panel .
Post the java log here
Cheers,
Michel
15 Replies 15
Michel Hegeraat
Level 7
Level 7
On the client machine, find the java directory, e.g. Program Files\Java\, in there is a directory jre6\lib\endorsed.
Make sure this last directory has write permissions for all 'users' on the client system.
Cheers,
Michel
Hello michel, thanks for your quick response.
yes, i found that directory on jre6. but how to make sure that directory has write permissions for all users ?
Hello michel,
i have changed the permissions setting on vbjorb.jar. right click on it -> properties -> select security tab. and change permission setting -> click edit (see the attachment).
but the problem is still same.
bebygone24
when i tried to open topology services from web browser , i got another error message. which always prompt me to install java plug in 1.6.0_24 (see the attachement), i have read and followed all the instructions and also installed java plug in 1.6.0_24 as they asked , but the error message is still same. they always prompt me to install java plug in.
i have restarted my laptop & also the browser many times. but still didn't work.
any advice you can give will be greatly appreciated.
I have seen this error when multiple Java versions are installed. While it is possible to work around it with some low level manual tweaking of the Java settings; the cleanest solution I have found is to first uninstall Java completely on the client. Then install Java from the distribution package delivered from the LMS server. That usually results in a clean working copy on the client.
okay, i'll try it. thanks for your advice
Hello marvin.
still not working ,
after i uninstall my java completely and tried to install java from distribution package from LMS server.
any other idea ?
Is it possible to open the topology services using any different browser?
Do you have any client firewall product active?
i used 3 different browsers : mozzilla, IE and google chrome
and i have turned off my firewall & antivirus.
I believe you may have changed the permissions on a file but I really meant the write permissions on the directory.
Full Control for all 'Users' is what I put in there.
Cheers,
Michel
still not working , still got the same error message.
maybe because i used windows 7. do you have java plugin with jacorb which support for windows 7 ?
Cheers,
Michel
i post it here
Hello all,
finally i can run the topology service on my windows.. thanks all, especially for you michel..
