need help to configure a PIX 501
powderskiing
hello everybody,
i need some help to configure my firewall pix 501. I have some probleme with the outside interface. With the PDM (System property/interface) i see that my outside interface is enable. But on the monitoring there is a red cross near the outside interface.
with telnet when i do "show interface" i can see this result:
interface ethernet0 "outside" is up, line protocol is down
i try to put the line protocol on UP but i find no way!!!
more over when i connect a PC on the outside interface (with the good IP, 192.168.4.2 for the PC and 192.168.4.1 for the outside interface) there is no answer with a simple ping!!!
wong34539
Level 6
Level 6
Based on your problem in configuring a Pix 501firewall device, I think the following document will provide u in-depth information about pix 501 firewall security appliances.http://www.Cisco.com/en/US/products/hw/vpndevc/ps2030/tsd_products_support_series_home.html.
And the below link will provide u with all the troubleshooting details.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_tech_notes_list.h
