Need Tcl script to run show command with piped inc/exc/redir options
ian.m.covington
Does anyone know the trick to having a Tcl script run a show command containing a "pipe" option? The following example does not work as is, but the show command works fine without a pipe option. I'd like to be able to extract an acl exactly as it exists in the running config either as a variable or redirect to a text file. Thanks!
Example: set testacl [exec "sho run | section ip access-list extended testacl"]
5 Replies 5
Joe Clarke
There have been numerous issues with tclsh and pipes.  These days I do not recommend using tclsh for any production use if you don't have to.  EEM Tcl is much more robust.  If you make this an EEM Tcl script, the pipe will work just as you want (but CLI commands are executed differently).  You can use the code at https://supportforums.cisco.com/document/12628061/migration-code-move-tclsh-eem-tcl to help convert your tclsh script to EEM Tcl.
I've found - running expect scripts - that I often have to add an extra "pipe element" to get results
  For example with ios
     send "show ip interface brief | inc Gi0/0/0 \n";
would not produce results, but
     send "show ip interface brief | inc Gi0/0/0|moteStuff \n";
would work correctly. Anyone know why this could be?
Pipe to include does not have tab complete and takes full syntax or regular expression that has to match the output.  There is not an interface called Gi0/0/0 so nothing matches and returns a blank line.   If you did "show ip interface brief | inc GigabitEthernet0/0/0 \n" that should work.
When you piped |moreStuff into the command that is a "OR".   |Morestuff syntax must have produced a match.
Thanks Daniel
You're correct, I took an example from a file I had that I had not tested.
However .... Look at the example below - include with multiple arguments
Why does it not match "addr" until I add another argument?
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#sh run int Gi0/0/0 | inc interf|desc|addr
interface GigabitEthernet0/0/0
description SV1-ATT-MPLS-100Mbps-CID-IUYF.105978..ATI
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#sh run int Gi0/0/0 | inc interf|desc|addr|somethingElse
no ip address
eeudtc-zagreb1-gw#
eeudtc-zagreb1-gw#
Robert,
When I copied your command "sh run int Gi0/0/0 | inc interf|desc|addr " I got the same output as you.   Then I noticed there is a space after the "r" in addr so it does not match.   When you put the pipe in after addr it got rid of the extra space after addr.
