need to download Netformx monitoring tool
Pandian G K
Hi ,
  Can any one help me in downloading  netformx monitoring tool . Trail version can also will do since i am planing to test it before implementaion .
Thanks in advace.
Pandian.
6 Replies 6
Martin Ermel
here is some more information about CDS (Cisco Discovery Service) for which NetformX can be used; AKAIK, the tools you can use for this must be purchased, - it is the CDS which is free for Cisco partners;
This e-mail address should reach persons who can give detailed information on it: cds-info(at)cisco.com
to get an eval version, have a look here: http://www.netformx.com/buy-it
special infos for Cisco partners can be found here: http://design.netformx.com/cp
also see the IBLM page: http://www.cisco.com/cisco/web/UK/partners_resellers/iblm/index.html
Hi martin ,
thanks for your info. I have downloaded this application .
Can you please provide  deployment/configuration guide.
Rgds
pandian.
netfromx seems to have a wide range of learning resources, which you can easily find if you search form them. Some examples are;
NetformX Discovery -Step by Step Guide
at the end of this page you have a list to some resources for "Discovery" and also for general resources and training material ("Training" at the bottom in the yellow box)
and the learning navigator
And Pandian_G_K, please keep in mind, that it is not a good practice to post the same issue/question multiple times in different sections of the same forum;
https://supportforums.cisco.com/thread/2182342
If you have done so, and you get an answer in one thread, be fair and reference the other thread to the one which contains the conversation - otherwise people could spend time to answer your yet solved question.
Hi Martin ,
rgds ,
pandian
Hi All,
How to get free trial registration key for netformx?
