netconf over sshv2
jay.ganatra
Community Member
I have WS-C2960S-48TS-L switch and it's SW Version is 15.0(1)SE2.Does this switch has feature 'netconf over sshv2' (Means in 15.0(1)SE2 sw version)?. Or, Do i need to upgrade to specific ios version for this mentioned feature ?
JP Miranda Z
Cisco Feature Navigator
You can do a search with the feature netconf over sshv2 and this is going to show you all the platforms and software versions that supports this feature.
Hope this info helps!!
Rate if helps you!!
-JP-
Hi ,
Netconf over sshv2 starts from Cat4k onward, it does not support in 2900 Series..
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Adnan
