Netconf/YANG on CSR1000v
p.hruby
I'm playing with Netconf on CSR1000v but I'm still unable to test YANG feature.
I've added "netconf-yang" command into my configuration but when I establish ssh session I obtain the following capabilities only:
$ ssh -2 -s cisco@10.105.139.154 netconf
Password:
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities><capability>urn:ietf:params:netconf:base:1.0</capability><capability>urn:ietf:params:netconf:capability:writeable-running:1.0</capability><capability>urn:ietf:params:netconf:capability:startup:1.0</capability><capability>urn:ietf:params:netconf:capability:url:1.0</capability><capability>urn:cisco:params:netconf:capability:pi-data-model:1.0</capability><capability>urn:cisco:params:netconf:capability:notification:1.0</capability></capabilities><session-id>3766690272</session-id></hello>]]>]]>
The following logs I obtained after I had entered the netconf-yang command:
*Oct 27 13:08:15.062: yang-infra: netconf-yang server has been notified to start
*Oct 27 13:08:31.521: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:csr1000v-1 ID:1938 User: has connected.
*Oct 27 13:09:54.043: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.vtyserverutild Host:csr1000v-1 ID:8747 User: has connected.
*Oct 27 13:11:22.078: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:csr1000v-1 ID:1211 User: has connected.
I'm using CSR1000v with IOS XE 16.03.01 in VIRL environment.
Petr
p.hruby
Port 830 must be used for Netconf/ssh communication.
