NetConfig for RME 3.5!!
sabrouch001
when I execute a job for 3 IOS switchs cat3550 it fails for 2 devices and I didn't understand the cause please anyone can explain this :
*** Device Details for 172.22.50.101***Transport==>Telnet***
Device failed during update.
===> Update Result: failed
Error: PGM_NM=Configuration Archive:6377:TYPE=unassigned message type::Resource C:/PROGRA~1/CSCOpx/files/archive/config/5/20060123102424running.cfg was checked by another user under application Function Id:302 - Config Editor
Cause: PGM_NM=Configuration Archive:6378:TYPE=unassigned message type::The resource was already checked out.
Action: Only one user can checkout a resource.
- CLI Output -
nhabib
Level 9
Level 9
Go to:
RME -> Config Management -> Config Editor
Once it opens up, go to:
Tools -> List Checked out Files
Check-in the files then try the Netconfig job again
r-kaye
Hi there, how are you?
I have just noticed the issue you have here. SNAP! I have the same.
I see this was posted 3 months ago, did you find a resolve at all? I would be interested.
Many thanks, Rory
