Syslog message for configuration mode -
getwithrob
Level 3
Level 3
On IOS, the severity 5 %SYS-5-CONFIG_I: gets logged to the device and if RME is set to listen to sylog messages, it knows there has been a change and to update the config. How does it work on CatOS set based switches? Is there a syslog messages that occurs?
getwithrob
Level 3
Level 3
I forgot to mention that the device is configured to send syslog messages to a syslog server.
For CatOS the message is %SYS-6-CFG_CHG
Thank you.
Here's a problem I see though:
The default logging level for CatOS is 4 or Warnings - set logging server severity 4
This means that CatOS devices set at the default logging level won't send a syslog message that the configuration has changed....
