Netconfig window error
woods8
Through a browser I cannot bring up the netconfig or config editor window?
But if I use Terminal services to the Ciscoworks server I can quite happily use netconfig & config editor. The machines are identical in build and software installs.
nhabib
Level 9
Level 9
I am assuming you are using RME 3.4 or 3.5 ?
If so, both ConfigEditor and NetConfig use the java plug-in
Check what version(s) you have installed on the client.
Another thing to check is the proxy setting in the browser you are using (if I.E. tools -> internet options -> connections -> LAN settings, and make sure nothing is selected)
