10-10-2023 11:14 PM
Hi, we want to monitor the traffics flows on mpls interface of C6800 core switch.
The interface command of netflow
mpls flow monitor example-monitor input
mpls flow monitor example-monitor output
The problem is when we define flow record, it shows a lot match rules are not correct.
Can anyone please advise the examples rules of flow record which are supported by C6800? Thanks in advance!
10-10-2023 11:22 PM
Hello @Herman2018,
Please refer here:
https://community.cisco.com/t5/switching/how-to-configure-netflow-on-6807/td-p/2595925
10-10-2023 11:39 PM
Thanks M02@rt37 for your prompt advice. However, this 2x examples are for non-mpls interface. Our case is to monitor the traffices on mpls interface.
10-10-2023 11:54 PM
flow record mpls-flow-record
match mpls label
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
10-11-2023 12:02 AM
you need to provide sample output what is not correct in your point of view.
what you expect from the netflow MPLS outcome ?
what version of Code and Supervisor on Cat 6800 switch ? (show version and show module , also complete netflow configuration will be helpfull here)
below MPLS aware NetFlow config for reference in case you missed any syntax and there is Limitation also mentioned :
10-11-2023 12:31 AM
thanks M02@rt37 . The link you shared is not accessible. I can't share the error message right now. will post later, thanks.
10-11-2023 12:44 AM
