TLV-Select seems to be missing in PT [Packet tracer][NOOB]
mblackshore
Hello I'm new.
I wonder if you know if full LLDP is in packet tracer?
I'm following education material where I can restrict TLV (Type length value) traffic types.
In config terminal, he is using
lldp tlv-select ?
Cisco switch then spits out.
This does not seem to work on Level2 or Level 3 switches in Packet tracer.
Is this only available on actual hardware?
Joseph W. Doherty
PT often doesn't include features (especially advanced features) found in "real" products.
5 Replies 5
Joseph W. Doherty
mblackshore
that is good to know!
BTW, if your looking for software that accurately supports Cisco features, you need hardware emulation software, like GNS3, or perhaps like Cisco's CML.
Its easier in that case to just use
Devnet: https://devnetsandbox.cisco.com
It looks like one can run the sim upto 1 week at a time. Limited to 14 nodes for free. If you want more nodes, you will need to pay
https://www.cisco.com/c/en/us/products/cloud-systems-management/modeling-labs/index.html#~licensing
Yup, believe that's their on-line version of CML.
