Netflow iWAN recommendations.
taburley
I have a customer who is trying to determin if he needs two different netflow configurations to replace the v5 default he was running prior to needing to change to Flexible.  He is looking for recommendation regarding using one netflow for WAN interfaces and another for iWAN interfaces.
The CU needed to move from v5 to v9 and ran into a few bugs.  That took us down the Flexible Netflow path.
Any professional recommendataions?
WAN -
flow record RECORD-1
 match ipv4 tos
 match ipv4 precedence
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 match interface output
 match flow direction
 collect ipv4 source mask
 collect ipv4 destination mask
 collect flow sampler
 collect counter bytes
 collect counter packets
 collect ipv4 dscp
flow exporter EXPORTER-1
 description FNFv9
 destination 1.1.1.1
 source loopback0
 transport udp 9995
flow monitor MONITOR-1
 exporter EXPORTER-1
 record RECORD-1
iWAN
flow record Record-FNF-IWAN
 description Flexible NetFlow for IWAN Monitoring
 match ipv4 dscp
 match ipv4 protocol
 collect routing source as
 collect routing destination as
 collect routing next-hop address ipv4
 collect ipv4 id
 collect ipv4 source prefix
 collect transport tcp flags
 collect interface output
 collect timestamp sys-uptime first
 collect timestamp sys-uptime last
 collect application name
flow exporter Export-FNF-IWAN
 description FNFv9
 destination 1.1.1.1
 source Loopback0
 transport udp 9995
 option interface-table
 option application-table
flow monitor Monitor-FNF-IWAN
 description IWAN Traffic Analysis
 cache timeout inactive 10
 cache timeout active 60
0 Replies 0
