Netflow monitoring through management interface
zohebS
I have configured the netflow on my cisco ISR 4451 management interface but I am not able to collect data on my NMS server. Also i have given static route to my NMS server
Source 10.146.96.101
Destination (Collector): 10.146.104.35
UDP Port :5111
Below is the configuration
flow exporter export-jio-management
destination 10.146.104.35
source GigabitEthernet0/0/3
transport udp 5111
template data timeout 60
option application-table timeout 60
option application-attributes timeout 300
flow monitor monitor-Jio
cache timeout active 60
record record-Jio
interface GigabitEthernet0/0/3
description *** Management ***
vrf forwarding monitor-vrf
ip flow monitor monitor-Jio input
ip flow monitor monitor-Jio output
ip address 10.146.96.101 255.255.255.0
negotiation auto
balaji.bandi
There are 2 things  here
Source interface using that interface to send Data to NMS
Source interface where you want to collect the data on the devices.
on your case both you using same interface  interface GigabitEthernet0/0/3  - is this correct ?
check some example working one
https://www.balajibandi.com/?p=1383
BB
Yes, Because I am collecting the data from my management interface which is 0/0/3.
