netflow on 6509
mbasalp
Community Member
hi,
we've a 6509 with the ios version 12.2(18)SXD5.
Even if i don't enable netflow per interface , i could see a lot of traffic pass the router with the command " show ip cache flow"
And the output is the same when i try for example "show ip cache flow vlan 10" command.
Is it a way to configure netflow data only per interface of 6509 like the routers ?
looking forward your replies.
regards
yjdabear
Huh? You mean there's no "ip route-cache flow" configured per interface?
mbasalp
Community Member
yep, there's no such command configured per interface.
Do you have any ideas ?
